The cheapest you can go with solar? | 24 comments (24 topical, editorial)
Re: The cheapest you can go with solar? (3.00 / 0) (#14)
by Simple serf on Sun Apr 6th, 2008 at 07:28:23 AM MST
Well,
I have been running those cheap 15w panels from Northern for about 4 years, and I am currently expanding to all of the area I can use. I am replacing my relay type charge controller with a Xantrex C35, I am installing a Trimetric 2020, a xantrex 700W inverter, and I am going from 150AH to 500AH. With all of the fuses, wiring, and parts, it will come to about $1100 for the new work and I have a total of about $1300 into the system now. With all of the new stuff and the extra panels, I will be able to run all of my electrical loads except for refrigeration, and I am currently looking at a Sunfrost fridge and a older propane fridge. Just depends on what you want to run. My effiency is pretty high, so I can use the 700W inverter without any problems.
My work with solar is because I have always enjoyed working with wind and solar power, and because I am a bit of a survivalist.
Paul
Re: The cheapest you can go with solar? (3.00 / 0) (#15)
by freeEnergy4me on Sun Apr 6th, 2008 at 10:12:14 AM MST
That sounds like me. I also bought those Northern panels. Although the idea of having one 150W panel instead of 10 15W is very appealing!  At this point I think they are about the same price, maybe a little more for something like a Kyocera.
I am also a bit of a survivalist. More in the vane of "if I get fired and can't find a job" than "if the Russians invade".  It's good to know the electric company can't turn my power off...or that it won't matter if they do.
The cheapest you can go with solar? | 24 comments (24 topical, 0 editorial)
