I figure it will keep heat longer than water.[ Parent ]
If only I could buy those blocks they use to coat the Space Shuttle, lol. They absorb the heat incredibly well!
What is the best capacitor of solar heat? That is my quest! [ Parent ]
The one main gain from using the oil is that unless your located in -20F weather for days on end, it's not likely to freeze, so a drain back system shouldn't be needed. BUT there's the possible need for a pump to move the stored/heated oil to place needing heat etc...
Tranny Fluid can be a mess to work with too, it likes to find leaks and make messy puddles.
Hope this helps and doesn't stop you from trying. Any use of even a little bit of the solar heating gains will go a long way to helping keeping the bills down along with that way cool feeling of saying "I did this"
PS, Don't do like I did, and get the idea that mineral oil and a small submersible water pump will work. Worked, but mineral oil gooped up the pump. wan't a good thing thing. Pump cost me $5, oil for 20fl.oz was $5. mess was all day. And the Tranny oil would destroy the cheap plastic they're made of. [ Parent ]
