Vinyl ester resin casting lessons | 12 comments (12 topical, editorial)
Re: Vinyl ester resin casting lessons (3.00 / 0) (#3)
by snowcrow on Wed Apr 30th, 2008 at 08:24:28 PM MST
  Thank you Boss, for posting your mishap!!!  You just save me a lot of pain and expense! I was about to make the same mistake of mixing the filler in first and bolts too!!  I can see now were it may not be such a good idea.
  I thought I also seen a void on the inside edge of your mold. Sealing voids and making the inside of the mold as smooth as possible, before applying your release agent, will make it just about fall right out of the mold after it hardens.
  I looked in Hugh Piggott's How to Book, earlier today and found that he did add the hardener first.  I guess trying to save a minute during the process is not worth the risk, as you just experienced.
  I'm glad bad weather held me up the last few days, otherwise I'd be singing the same sad tone.  Hope your second attempt is a success!!
Blessings, Snow Crow
Re: Vinyl ester resin casting lessons (3.00 / 0) (#10)
by Boss (brians.outfit(at)gmail.com) on Fri May 2nd, 2008 at 06:21:07 AM MST
Yes in the photo there was a few negative areas, However before we poured I did an hour or more with a Dremal Tool spinning a small sanding drum removed all the places for resin to catch and not release, indeed I beveled the edges of the mold both at the outside edge and the inner disk. This is just one reason the failure was disheartening.
Brian Rodgers
Vinyl ester resin casting lessons | 12 comments (12 topical, 0 editorial)
