Home Made Francis turbine | 4 comments (4 topical, editorial)
Re: Home Made Francis turbine (3.00 / 0) (#4)
by scottylucas on Mon Apr 28th, 2008 at 12:39:45 PM MST
What about if you used a impeller out of a torque converter, I mean, machine a pipe to go directly around the impeller and have an output shaft which drove a generator, the impeller in a torque converter is made to be driven by fluid i do believe. Ill take some photos of the banki turbine i have built and of the impeller on the torque converter i have an idea of using. if anyone has tried this before feel free to comment:)
Home Made Francis turbine | 4 comments (4 topical, 0 editorial)
