cheers bob golding[ Parent ]
In my RE systems I like to use soldered connections. But my max wire sizes now are 12 to 8 gauge and is fairly easy to solder with a blowtorch. My suggestion would be to solder the connections and use heatshrink tubing to insulate as much of the bare connection as possible. If soldering isn't an option then use connections with screw terminals, and if they aren't available then Crimp the connections. Use Screw Terminal strips for all other connections that are not soldered. W o o f -={([ Parent ]
