Hydro Electric Dam Stalled Posting | 15 comments (15 topical, editorial)
Re: Hydro Electric Dam Stalled Posting (3.00 / 0) (#11)
by Ungrounded Lightning Rod on Wed Apr 9th, 2008 at 04:50:17 PM MST
The current issue is that we require an Environmental Assessment to be completed before funding is available from banking institutions (up to 100K.)
Do you plan just to restore the original mill - at least the part that converts water to mechanical power - or do you plan to replace it with something different?
Is there an old millpond that's silted up and needs to be cleaned out, or is this site on a river?
Is the old mill broken down so fish can pass through it?
Since there's already a mill there, with existing waterway modifications to power it, you won't be doing major alterations to the waterway to set it running again.  That should greatly reduce the environmental impact - and the cost of the study - compared to a from-scratch instalation.
Re: Hydro Electric Dam Stalled Posting (3.00 / 0) (#12)
by vawtman (vawtman(at)charter(dot)net) on Wed Apr 9th, 2008 at 05:20:15 PM MST
ULR heres what i found.
http://www.foghorn.ca/herronmills/?q=node/4
Re: Hydro Electric Dam Stalled Posting (3.00 / 0) (#13)
by HerronMills (herronmills@aol.com) on Thu Apr 10th, 2008 at 05:15:18 AM MST
(User Info) www.foghorn.ca/herronmills
Our plan is to restore the mills...the first original one only has a foundation and a turbine in it (size 30 X 40) and sits on the bank of the Clyde river.  Our thoughts are to use that one for the fish ladder.
On the other side of the river is the large Lumber and Grist mill (50 X 150') with a 12' X 50' opening for the water. Our plan is to use the orginal footprint. Concepts of the new mill can be found on our website. All of the orginal equipment from the mills still exists in the mills and will have to be removed but will make for a nice Museum once completed.
The water is redirected off the river and channeled into the mill and then back into the river..yes it will have to be redefined and cleaned out.
The mill pond will be the river itself...we can flood river back 600' and will have 12' of head at the dam.  The dam itself will be roughly 60 feet wide but including the mill and shoreline we will have 120 of water 12 feet high.
I agree that this should be alot more easier on the EA process...more so doing modification to existing structure versus from Scratch but quotes are not showing that.  Concidering we own the 600' of river that will be flooded, both sides of the river where the dam is and 1500' of river on both side down river.
Ed
Re: Hydro Electric Dam Stalled Posting (3.00 / 0) (#15)
by jeffbirkle on Wed Jun 11th, 2008 at 11:02:51 AM MST
Hi Ed.
I've been busy designing Wind and Water Turbines, so i haven't come across your post till now.
Looks like we are in the same boat!
I've been looking for a smaller site (10 to 60kw) to do the same thing. Just 2 hours south west of you, in-near Flinton ONT. There is an old dam in Flinton on the Skootamatta river.
The Quinte Conservation Authority owns around 20 existing dams in south-central ONT including the Flinton site. They are building new power stations at some of these sites. You can look up their web site.
My neighbour in Flinton, who works at the power stations for Hydro Generation in Campbellford says, that the Ont Government wants to increase Hydro electric by 150 plants!
How do we get the ball rolling??????
I'll keep in touch.
Good luck.
Jeff
Hydro Electric Dam Stalled Posting | 15 comments (15 topical, 0 editorial)
