Be aware these batteries weight 28KG as well. If your back is dodgy, don't try lifting it!
The rating for this battery is C/20, which is 4.5 Amps. I don't think I've ever really used more than 1.5A total except when running my inverter from it so it does very well capacity wise.http://www.repowered.co.uk - My Renewable Energy site. msn[at]m3ezw.co.uk - my msn if you want a chat.
This is why you can never measure state of charge when charging floating or discharging. You can only measure this when the surface charge is removed. Standing for a minimum of 6 hrs or after a minute or so of discharge with a modest load. Even 12.9 is on the high side but some calcium based VRLA's can just make it. Typical full charge for most flooded cells is about 12.8V.
Flux[ Parent ]
Based on Flux's explanation, that's a normal behavior. We were doing better than we think. I'm glad it's not proved the other way around.
Thanks Abyss and Flux for the input.
Speo[ Parent ]
