Sine wave inverter/charger for small solar backup system | 18 comments (18 topical, editorial)
Re: Sine wave inverter/charger (3.00 / 0) (#6)
by cujet (cujet@aol.com) on Sun May 11th, 2008 at 08:24:03 AM MST
Not helpful.
I must admit that my communication skills are lacking, sorry. Can you point me in the right direction on how to edit my previous post.
Please understand that my inability to verbalize my thoughts properly really has nothing to do with my level of understanding.
Understand this: I GET IT. I understand inverters, solar and electrical power in general. Again, sorry for not being clear.
I'll try to be more clear.
What "pure sine wave" inverter/charger would function as either a UPS or full time unit, provide a peak of about 3000W and a running load of 500-600W, be reliable, quiet, reasonably priced and well made? Are the Taiwan ones on Ebay any good? Or should I only consider a Xantrex?
In my case, after a hurricane, I run my DIY Lister genset during the day. At night, I generally shut it down. The inverter would carry the fridge/freezer at night.
Take a look at my website, I trust that will clear things up a bit. I do have a home machine shop, I am skilled in welding and fabrication. I generally can engineer and construct anything I put my mind to.
http://www.cujet.com/html/other_projects.html
Feel free to look around my website at my work. And yes, I built the header, the bicycle, the turbo miata, the Listeroid. All DIY.
Re: Sine wave inverter/charger (3.00 / 0) (#11)
by ghurd on Sun May 11th, 2008 at 06:43:23 PM MST
The 120 AH isn't going to run much stuff very long.
That's about the same watt hours as a pair of golf cart batteries.
With a 600W load, that's about 25A. That's about an hour and a half.
SLAs won't last long with that kind of abuse.
I am not sure they will supply 3000W (125A) without the inverter going LVD.
A 3000W pure sine inverter waiting for a load might drain the batteries before morning.
Some units have a "sleep" function.  They wait for a load before turning on.  Not sure how that fits with the fridge.
I don't get the "function as either a UPS or full time unit".
The plan is to run it 24/7, even when the grid is on?
That's a lot of wasted power, like noticably jump the bill kind of wasted power.
The 24V and pure sine limits the choices.
Re: Sine wave inverter/charger (3.00 / 0) (#12)
by kurt on Sun May 11th, 2008 at 06:52:47 PM MST
most inverter/chargers will act as a pass through UPS and charge the batteries when connected to grid power..... i think that is what he wants.....
http://www.reresource.org/
IRC
Sine wave inverter/charger for small solar backup system | 18 comments (18 topical, 0 editorial)
