Sine wave inverter/charger for small solar backup system | 18 comments (18 topical, editorial)
Re: Sine wave inverter/charger for small solar bac (3.00 / 0) (#8)
by dnix71 on Sun May 11th, 2008 at 01:12:06 PM MST
You should make sure the inverter you buy can actually run the fridge.
I have a small upright freezer that uses about 200 watts running, BUT pulls 700 to start. I measured both with the Kill-A-Watt meter. Neither of my inverters will start that freezer. The pure sine inverter is rated 300run/600start and the mod sine inverter is rated 600run/1000start. So I don't believe the 'ratings' anymore.
The really nasty part is the Ames inverter doesn't trip out when trying to start the freezer. The output voltage drops to 60volts under load, but the freezer doesn't start and neither the inverters' overload breaker nor fuses trip. If that was left unattended something bad would happen.
Re: Sine wave inverter/charger for small solar bac (3.00 / 0) (#9)
by cujet (cujet@aol.com) on Sun May 11th, 2008 at 01:55:17 PM MST
Thanks for the info on the small inverters. I had not considered using a small inverter, as my surge loads may be fairly high. I suppose I will just bite the bullet and purchase a Xantrex 2000 or 3000 watt pure sine wave unit.
Remember that I get batteries every year, so the number of batteries will grow over time. Probably faster than they go bad.
The desire for Solar is simply for a backup to my backup.
Sine wave inverter/charger for small solar backup system | 18 comments (18 topical, 0 editorial)
