First test of Hughs 4ft alt. | 2 comments (2 topical, editorial)
Re: First test of Hughs 4ft alt. (3.00 / 0) (#1)
by electrondady1 on Sat May 10th, 2008 at 08:14:38 AM MST
jerry,
using this construction method,
 how do you set the mag/ coil clearance.
on one of the photos there were a few paint stir sticks laying around.
i am guessing that you fix your stator tight to the speaker chassis and then set the rotor position using some spacers and then lock it in place with those collars?
Re: First test of Hughs 4ft alt. (3.00 / 0) (#2)
by Jerry on Sat May 10th, 2008 at 10:15:21 PM MST
There are 2 alin set screws on the shaft to hub adaptor. I just slide the rotor to the desired position the tighten the set screws.
Yes the stator is secured to the speaker basket.
I did some no load DC voltage test today.
I ran the rpm up till one coil mesured 5 volt. This happened at 492 RPM.
In star at this RPM dc output is 22.5 volts. In "Jerry Rigged" the voltage is 25.5.
I think the real diferance will show up under load. There is a allmost sign wave shape on the scope.
Airheads Page
First test of Hughs 4ft alt. | 2 comments (2 topical, 0 editorial)
