There are 2 alin set screws on the shaft to hub adaptor. I just slide the rotor to the desired position the tighten the set screws.
Yes the stator is secured to the speaker basket.
I did some no load DC voltage test today.
I ran the rpm up till one coil mesured 5 volt. This happened at 492 RPM.
In star at this RPM dc output is 22.5 volts. In "Jerry Rigged" the voltage is 25.5.
I think the real diferance will show up under load. There is a allmost sign wave shape on the scope.
Airheads Page
