Air gap vs test coil voltage | 13 comments (13 topical, editorial)
Re: Air gap vs test coil voltage (3.00 / 0) (#10)
by ghurd on Mon May 12th, 2008 at 02:51:43 PM MST
How thick / long were the magnets?
Measured from one disk to the other disk.
I am guessing they were 0.5" or so.
Re: Air gap vs test coil voltage (3.00 / 0) (#11)
by SparWeb (sparweb at ANTISPAM_hotmail_com) on Mon May 12th, 2008 at 04:58:01 PM MST
Yes, didn't give much info, did I?
This was from the axial I built a year ago, RIP.  It had 1/4" thick magnets, each 1" diameter.  The two rotors had 16 poles, and the stator was 3/8" thick.  I only tested down to 1/2" air gap, where things could start scraping together.  I was doing the test to correlate what I could see in FEMM.
If you want to know more, I can dig up details about the coil, RPM, etc., or you can find it in my diaries and postings from about 2006.
Steven Fahey
Re: Air gap vs test coil voltage (3.00 / 0) (#12)
by Flux on Tue May 13th, 2008 at 01:19:41 AM MST
I think that if you neglect leakage and consider it over large gaps it is inverse square as the thing is based on the ratio of gap to magnet length ( magnet length constant)
Beyond gaps greater than total magnet length you will likely see increased leakage and with close magnet spacing you may see leakage effects with gaps at magnet length.
The linear approximation I gave is not really applicable with large changes in gap but works well enough if you don't stray too far from the magnets best operating point.
Air gap vs test coil voltage | 13 comments (13 topical, 0 editorial)
