Air gap vs test coil voltage | 13 comments (13 topical, editorial)
Re: Air gap vs test coil voltage (3.00 / 0) (#3)
by commanda (alwynne at unwired dot com dot au) on Sat May 10th, 2008 at 01:59:35 AM MST
Thanks Flux.
With a total magnet length of 20mm, changing the gap from 17mm down to 14mm should give approx 13% more volts.
Air gap vs test coil voltage | 13 comments (13 topical, 0 editorial)
