Hi Oztules
The most negative point is genny ground, so the caps are the right way around. It would have clearer had I posted all the circuit. It's here. I've tried adding diodes but the LTSpice model never shows anything but a few microamps going thru the diode. The real circuit may be different. I like your idea of adding a diode going back to battery +. It should limit voltage at the fets to whatever the genny produces plus the drop across the diodes.
I got it working again. I trashed the idea of the pot and added 10K resistors at the base of the fets between gate and source. I was hoping to see if there was any changes with resistance. Anyway, I'm going to try to see what happens when I change PWM frequency, power caps, and inductors.
