Inverter saga | 16 comments (16 topical, editorial)
Re: Inverter saga (3.00 / 0) (#9)
by Opera House on Mon May 12th, 2008 at 06:34:32 AM MST
If replacing those caps, I would add an additional two to four more.  All caps have an ESR that can result in heating.  A cap rated at 85C will only last a couple years if used full time.  External caps at the input terminals will work just as well.
Re: Inverter saga (3.00 / 0) (#12)
by wpowokal on Mon May 12th, 2008 at 05:44:48 PM MST
Good point, I will see if it fires up first, it does work hard particually in summer when ambient is in the high 30's to early 40's.
allan down under
Inverter saga | 16 comments (16 topical, 0 editorial)
