8 qt cel and milage results | 34 comments (34 topical, editorial)
Re: 8 qt cel and milage results (3.00 / 0) (#3)
by Tritium on Sun May 11th, 2008 at 01:53:18 PM MST
It only takes about 1.5vdc to crack a water molecule. You will get much less heat and water vapor by using 7 electrode sets in a series for normal auto voltages. You will have to come up with a different electrode assembly though. Most use 7 pairs of positive / negative plates connected in a series.
Thurmond
Re: 8 qt cel and milage results (3.00 / 0) (#4)
by electrondady1 on Sun May 11th, 2008 at 02:54:01 PM MST
this is very interesting tecker
carry on!
Re: 8 qt cel and milage results (3.00 / 0) (#6)
by tecker on Sun May 11th, 2008 at 06:34:35 PM MST
I don't know that heat isn't a good thing just a guess really the drier I installed as we started home removed all the vapor that was collecting in the tube . I my mind the cell should have as few connections as possible . As far as power factor . You have to consider those to be what ever it takes to polarize the mass in between the electrodes.
Re: 8 qt cel and milage results (3.00 / 0) (#16)
by electronbaby (roy<at>windsine.org) on Mon May 12th, 2008 at 08:36:55 PM MST
Try using PWM to feed your electrolyzer instead of DC. You will be able to vary the duty cycle and find the sweet spot for the size of your plates.
Have Fun!! RoyR KB2UHF
Re: 8 qt cel and milage results (3.00 / 0) (#21)
by tecker on Tue May 13th, 2008 at 06:15:23 AM MST
That's a good Idea I 've seen the frequency stated in a Meyer interview as 20Khz higher voltage and low amps .I'll try that soon .
8 qt cel and milage results | 34 comments (34 topical, 0 editorial)
