Motor burn up threshold | 14 comments (14 topical, editorial)
Re: Motor burn up threshold (3.00 / 0) (#3)
by JW1111 on Sun May 11th, 2008 at 05:54:18 PM MST
Thank you.  I have the 38volt Ametek.  I want to wire directly to a 24 volt battery bank.  When I do this my ammeter reads 3 amps in 20mph wind and my Pro Star solar controller indicates that it is charging.  I appreciate any suggestions you  may have including suggesting a 24volt charge controller I should use in line between the generator and the batteries. But most importantly I would like advice on how not to burn up my motor. I use the bracket that ED Lenz builds and as far as I know there is no way to incorporate furling with it.  And there is no internal regulation. Thank you.
Motor burn up threshold | 14 comments (14 topical, 0 editorial)
