Charge control @ 60VDC? | 12 comments (12 topical, editorial)
Re: Charge control @ 60VDC? (3.00 / 0) (#3)
by Opera House on Mon May 12th, 2008 at 06:20:29 AM MST
I'd grab another discarded UPS and convert it to a voltage doubler and use two Harbor freight panels.  No use spending all that money on panels when you are limited in what you can charge these 5AH batteries at.
Re: Charge control @ 60VDC? (3.00 / 0) (#4)
by Old F on Mon May 12th, 2008 at 07:09:06 AM MST
Pvale
What hamfest  was it ?
You mite be better off selling it at this years hamfest seeing you got it working.
An use the money toward a new 12 volt inverter an a charge controller .
This would give you more flexibility to add on
to you system later.
60 volts is an odd duck  an you would have to  do some  home brew to get going.
An if the inverter goes out you could have a hard time replacing it.
Old F
Re: Charge control @ 60VDC? (3.00 / 0) (#6)
by veewee77 on Mon May 12th, 2008 at 09:18:38 AM MST
  1. volts would be ok. . . But, if you are going to be running mostly AC Line-level devices and equipment, you would be far better off in the long run to start at 48V from the get-go instead of having to upgrade later.
  2. V systems require very heavy wiring on the 12V side and copper is not cheap these days. 48V systems don't require such heavy wire, so the wiring will be cheaper. The 48V equipment usually has better features and in some cases may even be less expensive than the 12V equipment, and in many cases is more efficient.
If you are intending to go off-grid anytime, you'll be money ahead starting out at 48V on your system.
As far as that UPS goes, I would just use it as it is for backup power, which is what it is designed to do. If the power fails, it will carry small, required loads for a time. I wouldn't permanently wire it into your house because that opens up a complete new can of worms. Using it as it is is already approved. Connecting solar panels to the battery to charge them as an alternative method might still be allowed, provided that thing is not permanently connected into your house.
I have used several different UPSs around my place for backup power. Example, I have a 7KW Ferrups unit that runs on 48Volts and puts out 120/240VAC. It lives out in an outbuilding and I have a long extension cord that I run into the house as needed to power some things I need if the power fails.
No code violations that way. . .
Doug
P.S. On a side note, if anyone wants that 7KW Ferrups, I'd sell it. . .
Charge control @ 60VDC? | 12 comments (12 topical, 0 editorial)
