What hamfest was it ? You mite be better off selling it at this years hamfest seeing you got it working.
An use the money toward a new 12 volt inverter an a charge controller .
This would give you more flexibility to add on to you system later.
60 volts is an odd duck an you would have to do some home brew to get going.
An if the inverter goes out you could have a hard time replacing it.
Old F [ Parent ]
As far as that UPS goes, I would just use it as it is for backup power, which is what it is designed to do. If the power fails, it will carry small, required loads for a time. I wouldn't permanently wire it into your house because that opens up a complete new can of worms. Using it as it is is already approved. Connecting solar panels to the battery to charge them as an alternative method might still be allowed, provided that thing is not permanently connected into your house.
I have used several different UPSs around my place for backup power. Example, I have a 7KW Ferrups unit that runs on 48Volts and puts out 120/240VAC. It lives out in an outbuilding and I have a long extension cord that I run into the house as needed to power some things I need if the power fails.
No code violations that way. . .
Doug
P.S. On a side note, if anyone wants that 7KW Ferrups, I'd sell it. . .[ Parent ]
