Charge control @ 60VDC? | 12 comments (12 topical, editorial)
Re: Charge control @ 60VDC? (3.00 / 0) (#7)
by Ungrounded Lightning Rod on Mon May 12th, 2008 at 02:56:26 PM MST
Check to see if the batteries are floating rather than being tied to the line neutral or case.
If they are, you could put your protective ground a couple batteries from one end.  Then you'd have a -24v system and a +36v system.  B-)  Put the batteries in separate boxes and only bring the two "halves" together at the inverter - at a covered connector.
Limit for "low voltage" is typically 50v nominal.  This is because that's about as high as you can go before you start getting a grab-and-get-stuck-to-it electrocution hazard.
I suspect it's actually 50v because Bell figured that out and standardized on 48V (to minimize copper usage within the constraint of not electrocuting their workers), then the codes were written taking the phone company's usage into account.  B-)
Re: Charge control @ 60VDC? (3.00 / 0) (#8)
by ghurd on Mon May 12th, 2008 at 03:46:39 PM MST
Hey ULR,
um... CRAP!
About that whole "have a -24v system and a +36v thing".
Timely smack in the face. (mine)
Thanks,
Re: Charge control @ 60VDC? (3.00 / 0) (#9)
by Opera House on Tue May 13th, 2008 at 07:37:58 AM MST
Picture clearly shows 5 batteries in series.  It is just not that hard to boost voltage up to 60-72 volts from any 24V or higher source.  Especially  when AH batteries would limit the current to less than an amp.  No need to worry about code when wiring is internal to cabinet.  I'd take it in a heartbeat.
Charge control @ 60VDC? | 12 comments (12 topical, 0 editorial)
