prop shape needs to be flat on windward side? | 24 comments (24 topical, editorial)
Re: prop shape needs to be flat on windward side? (3.00 / 0) (#15)
by Stonebrain on Tue May 13th, 2008 at 05:43:56 PM MST
If you take a symmetrical airfoil,naca 0020 or so,the sides are ..kind of..
flat from the thickest part to the trailing edge.What counts is the angle,more than the exact shape.If I look at your yellow thing(don't forget to drink your coffee),I would say it's not so bad.
naca 0020(the lowest one)The upper is the same,but the chord bended on a circle.
Re: prop shape needs to be flat on windward side? (3.00 / 0) (#16)
by Norm (peppysue@suite224.net) on Tue May 13th, 2008 at 07:44:27 PM MST
Yes the yellow thing is more like the bottom one
Had all three made today....got a couple of brief
6mph gust...just a glimpse that it might work.
  I think it's too large going to shorten the rods
so it will be 30inches from 36inches estimated
about 120 rpm (no load) ....need more research
( that's spelled more wind) they so seem to work
well....but maybe not good enough...fun nevertheless
(about 8 cups coffee later)
( :>) Norm
prop shape needs to be flat on windward side? | 24 comments (24 topical, 0 editorial)
