prop shape needs to be flat on windward side? | 24 comments (24 topical, editorial)
Re: prop shape needs to be flat on windward side? (3.00 / 0) (#18)
by Norm (peppysue@suite224.net) on Thu May 15th, 2008 at 09:10:59 PM MST
the problem is hand carving a concave windward side to a piece of wood
Bob....No problem there...you just make a hand
tool ...scraper blade from an old handsaw grind the
tool to whatever radius you want.
( :>) Norm
Re: prop shape needs to be flat on windward side? (3.00 / 0) (#19)
by elvin1949 (elvin1949@yahoo.com) on Thu May 15th, 2008 at 11:48:30 PM MST
 You took the words right out of my mouth.
I make scrapers all the time for different things when working with wood.
Elvin
Re: prop shape needs to be flat on windward side? (3.00 / 0) (#20)
by Norm (peppysue@suite224.net) on Sat May 17th, 2008 at 08:26:45 AM MST
Watch it Elvin usually only old timers know about
stuff like custom hand woodworking tools !
  BTW liked that Billion thing in the E-Mail !
( :>) Norm
Re: prop shape needs to be flat on windward side? (3.00 / 0) (#21)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Sat May 17th, 2008 at 12:16:27 PM MST
A useful search term is "draw knife"
http://www.endtimesreport.com/pictures/draw_knife.jpg
You could make one with a perfect size of handles and frame for your size of projects, and make the blades separate, so they could be changed to different shapes, or easily replaced when sharpening wears them down too low.
Re: prop shape needs to be flat on windward side? (3.00 / 0) (#23)
by elvin1949 (elvin1949@yahoo.com) on Sat May 17th, 2008 at 03:35:25 PM MST
 HF sells draw knifes and spokeshaves.
Both good woodworking tools.
Elvin
Re: prop shape needs to be flat on windward side? (3.00 / 0) (#22)
by elvin1949 (elvin1949@yahoo.com) on Sat May 17th, 2008 at 03:33:01 PM MST
 I thought you would.My sister is always sending me junk.Most of the time i through it away.
 Have fun
Elvin
prop shape needs to be flat on windward side? | 24 comments (24 topical, 0 editorial)
