Would this work? | 9 comments (9 topical, 0 editorial)
Re: Would this work? (3.00 / 0) (#2)
by martin1 on Tue May 13th, 2008 at 03:20:06 PM MST
It seems like this thing can be used both as a motor and as a generator.
Re: Would this work? (3.00 / 0) (#5)
by Flux on Wed May 14th, 2008 at 12:14:50 AM MST
Yes looking at the second plate it implies that it may have been used as a grid tie generator.
Any induction motor will generate if driven above sync speed when connected to the grid.
For a stand alone generator you need to supply the magnetising current by capacitors and it is a less stable situation.
If the speed rating is as a generator then it may be 10 pole, you would need to do a bit of investigating to be sure. Not sure why the motor and generator plates have the same speed.
Build yourself a 130kW wind turbine and grid tie it.
