Dumpload/Charge controller | 6 comments (6 topical, editorial)
Re: Dumpload/Charge controller (3.00 / 0) (#5)
by WindJuggler (ikislol _at_ gmail _dot_ com) on Thu May 15th, 2008 at 05:49:56 AM MST
That will depend on the MOSFET you will use. The design I'm making now will be able to handle 40-50A but with a few minor tweaks it will be able to handle even more.
The major limiting components are the Terminal blocks and the MOSFETs. The connections on the board will have to be adjusted by placing a wire parallel with it.
Wim
Dumpload/Charge controller | 6 comments (6 topical, 0 editorial)
