16 pole gen finished and working | 15 comments (15 topical, editorial)
Re: 16 pole gen finished and working (3.00 / 0) (#10)
by Jason Wilkinson (jason_wl48@hotmail.com) on Wed May 14th, 2008 at 02:07:06 PM MST
To wind another stator (i'll have to hide from the wife to do this and be ending up with 3 spare ones) the cost of the wire is far less than a 24 volt inverter. In the coming weeks   D V  i'll wind with 2 in hand #14 36 turns
 ps how can i submit pictures with the post
  Jason
Re: 16 pole gen finished and working (3.00 / 0) (#13)
by snowcrow on Thu May 15th, 2008 at 04:32:40 AM MST
Hi Jason, 2 in hand #14 36 turns is fine for 3 coils per phase, but you have 4 coils per phase.
  1. turns x 3 coils = 108 turns per phase.
  2. turns / 4 coils = 27 turns per coil.
Blessings, Snow Crow
Re: 16 pole gen finished and working (3.00 / 0) (#14)
by Jason Wilkinson (jason_wl48@hotmail.com) on Thu May 15th, 2008 at 10:02:27 AM MST
Thanks Snowcrow   so it looks like 27 turns of 2 strands of #14 awg magnetic wire
 Jason
Re: 16 pole gen finished and working (3.00 / 0) (#15)
by Flux on Thu May 15th, 2008 at 01:27:55 PM MST
I would be inclined to suspect that 27 turns will be ok for 10ft.
Before winding a new stator I would try running the existing one into higher voltages until you then find the correct load speed.
From Ghurd's figures you are way better at 24v, I would also try 36 as I think it may do better. If it does then try 48 and if that is worse you have gone too far.
Then say it worked best at 36v you would use 1/3 of the existing turns. That way you have your result without more trial and possibly error.
16 pole gen finished and working | 15 comments (15 topical, 0 editorial)
