16 pole gen finished and working | 15 comments (15 topical, editorial)
Re: 16 pole gen finished and working (3.00 / 0) (#2)
by Jason Wilkinson (jason_wl48@hotmail.com) on Wed May 14th, 2008 at 11:28:26 AM MST
It looks like i've jumped in at the deep side of the pool (an old Barbadian saying) like building a turbine, getting it to stay on a tower,spin and produce some voltage is far easier than understanding terms like "stall" and how much watts it should make when operated at its max.I thought it would get easier as i progress but i'm getting more confused   Thanks anyway for responding
    Jason
Re: 16 pole gen finished and working (3.00 / 0) (#3)
by Jason Wilkinson (jason_wl48@hotmail.com) on Wed May 14th, 2008 at 12:13:21 PM MST
I've just disconnected the batt from the turbine and it sped up going all the way to the 70 v mark and and climbing  when i reconnected the batt there was a frightening  spark and the amp meter shot up over 10 amps  before returning to 4 amps the batt are connected in series to make 24 v.   To me this turbine is making power, maybe i'm not using it wisely
     Jason
Re: 16 pole gen finished and working (3.00 / 0) (#4)
by Flux on Wed May 14th, 2008 at 12:37:56 PM MST
I have had a quick look at your figures and I suspect your cut in is below the 110 rpm that you quote. If you can find enough batteries it would be interesting to try 36v and even 48v to find out where it matches best. You would then have a far better idea where you are aiming for.
You have already doubled the power from 4A at 12v to 4A at 24v. I am sure you are still stalled.
16 pole gen finished and working | 15 comments (15 topical, 0 editorial)
