With a 10ft prop you will have more power to get the thing out of stall. Even so I think you will need to run at 24v especially with the single strand of #14 wire.
When you do break out of stall I think you will be surprised what you can get out of it. You seem to be in a good wind area. If you get those winds regularly I would not aim for the lowest possible cut in speed. If you start producing at 8 mph you will likely do better than aiming for a few mA in lower winds.
Flux[ Parent ]
Given the output, etc, would anyone have a guess at a decent new stator for 12V?
Also the 12V amps such a stator could make with the same blades and rotors?
I had it figured at around 800W, however I am not good at this stuff, not even a little.[ Parent ]
