16 pole gen finished and working | 15 comments (15 topical, editorial)
Re: 16 pole gen finished and working (3.00 / 0) (#8)
by Flux on Wed May 14th, 2008 at 01:56:03 PM MST
Yes the bigger blade does turn slower and that will match the very low cut in speed better.
With a 10ft prop you will have more power to get the thing out of stall. Even so I think you will need to run at 24v especially with the single strand of #14 wire.
When you do break out of stall I think you will be surprised what you can get out of it. You seem to be in a good wind area. If you get those winds regularly I would not aim for the lowest possible cut in speed. If you start producing at 8 mph you will likely do better than aiming for a few mA in lower winds.
Re: 16 pole gen finished and working (3.00 / 0) (#11)
by ghurd on Wed May 14th, 2008 at 02:14:53 PM MST
I hope he wants a face to face apology...
Given the output, etc, would anyone have a guess at a decent new stator for 12V?
Also the 12V amps such a stator could make with the same blades and rotors?
I had it figured at around 800W, however I am not good at this stuff, not even a little.
16 pole gen finished and working | 15 comments (15 topical, 0 editorial)
