Delco Generator low output | 25 comments (25 topical, editorial)
Re: Delco Generator low output (3.00 / 0) (#13)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Thu May 15th, 2008 at 01:27:11 PM MST
Southbuck;
Since I put you in my post to TomW, I'll jump back in here and ask the original poster to foregive me.
I did post a suggestion or two for him.
I read your post,
No details on anything on other than what you got from the machine you bought, just a post.
Then you asked not to have comments. then have them removed.
Got Finn mad at TomW for doing what you asked.
Also, since this was your first time posting, as best I could find. We can't know your abilites with you saying so.
Most new posters give us a little of their back ground and what they're trying to do, not just post open voltage readings.
As you think TomW did, you assmued you knew where TomW was coming from.
Re: Delco Generator low output (3.00 / 0) (#14)
by Southbuck on Thu May 15th, 2008 at 01:46:02 PM MST
if tomw did what i asked he would have deleted MY post. and that was telling him simply that i dident ask for his opinion, which if he left it up you could have read it. my mistake was thinking i could use this site to actually keep records for myself, say diary. yes, i posted open voltage at low rpm with a delco alternator, this was intended to be nothing more than a reference for myself. once again,,,,diary. sorry to all, not here to cause trouble.
Re: Delco Generator low output (3.00 / 0) (#15)
by Southbuck on Thu May 15th, 2008 at 02:38:14 PM MST
http://www.windstuffnow.com/main/gm_alt_mod.htm
my no load voltage is even higher than this one.
Re: Delco Generator low output (3.00 / 0) (#18)
by vawtman (vawtman(at)charter(dot)net) on Thu May 15th, 2008 at 05:55:08 PM MST
Hi Bruce
 I (assume) your right and well put     :)
 Mark
Delco Generator low output | 25 comments (25 topical, 0 editorial)
