Delco Generator low output | 25 comments (25 topical, editorial)
Re: Delco Generator low output (3.00 / 0) (#6)
by finnsawyer on Thu May 15th, 2008 at 09:15:34 AM MST
I wasn't happy with the editors removing comments from your Post.  I can't even bring up my comment myself anymore.  It takes time to compose the comments, and if that practice continues I will probably abandon the site rather than continue wasting my time.  I had no particular complaint with closing the thread, but the comments should have remained.  I take a dim view of removing anyone's comments.  Once posted they should remain archived, warts and all.
GeoM
Re: Delco Generator low output (3.00 / 0) (#8)
by TomW on Thu May 15th, 2008 at 10:23:06 AM MST
Finn;
You are diverting from the thread but I will say this:
He took issue with my attempt to help, called us snobs and requested I not comment in his Diary and I should remove it. Also claimed he did not want comments. By removing the comment of mine it removed the replies. Per his request.
No need to comment because I already know you will automatically take the opposite view and it would simply further divert the thread.
Damned if I do and damned if I don't.
Thanks for your concern.
Tom.
Contact: IRC
Re: Delco Generator low output (3.00 / 0) (#9)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Thu May 15th, 2008 at 11:30:14 AM MST
Hello TomW
And did you thank him [southbuck] for his kind words by showing him the door? Your much kinder than I would've been
My apologies for straying from the post.
Re: Delco Generator low output (3.00 / 0) (#23)
by jimjjnn (jimjjnn at yahoo dot com) on Fri May 16th, 2008 at 04:36:29 PM MST
Tom W, You did Just Fine. Thanks
Jim Denver,CO
Delco Generator low output | 25 comments (25 topical, 0 editorial)
