Translucent/stick-on solar PV | 16 comments (16 topical, editorial)
Re: Translucent/stick-on solar PV (3.00 / 0) (#11)
by DamonHD (d@hd.org) on Sat May 17th, 2008 at 02:10:01 AM MST
Indeed, I can understand that.  And it's a nice idea.
But the implication is still that I'd have to get specially-constructed double-glazed doors, yes, which would be fiendishly expensive I'll bet!
Re: Translucent/stick-on solar PV (3.00 / 0) (#14)
by Ungrounded Lightning Rod on Sat May 17th, 2008 at 05:46:01 PM MST
They're fiendishly expensive WITHOUT the solar panel - just with low-E glass and a frame.  If the low-E coating could be made as a solar panel without a price change you'd get the power for the cost of the extra wiring.  If not, you get it for that plus the price difference (presuming you were going to install low-E windows anyhow).
That delta might be far less than the cost of a full-blown panel assembly - glass, frames, wiring, mounting, ...
Re: Translucent/stick-on solar PV (3.00 / 0) (#15)
by DamonHD (d@hd.org) on Sun May 18th, 2008 at 02:49:39 AM MST
OK, indeed.
Well, if we have to have some custom-made double glazing done, and it is entirely possible that some of our 40-year-old falling-apart stuff is going to need repair or replacement, then I'll see if we can put in (say) some of Schott's laminate stuff in the outer pane.
Translucent/stick-on solar PV | 16 comments (16 topical, 0 editorial)
