so from your comments i am to believe that the mutual inductance of two opposite wound coils on a single pole will have not adverse effects on the voltage of either coil?
if so, that is the answer to my question :)
yes i am working with a iron core machine, without neos, and tight airgap
thanks
bob g[ Parent ]
Basically true. The combined dual coils will be the same as drawing the same load from a single coil. With the dual coil arrangement there will be some change in the voltage of one coil if you remove the load from the other as there will almost certainly be a drop in the loading with one coil disconnected.
flux[ Parent ]
i would expect some change in output if you drop the load from one coil but was concerned whether the interaction of the two seperate coild magnetically would have adverse or cancelling effect.
ok,, now i will start the rewind and see what happens
thanks again one and all
