Motor to Generator operation Controller | 5 comments (5 topical, editorial)
Re: Motor to Generator operation Controller (3.00 / 0) (#2)
by jonas302 on Sat May 17th, 2008 at 05:56:17 AM MST
remote car starters moniter the voltage of the battery to disengage the starter
not being an electrical engineer I might be tempted to try to modify one  you could even use the brake switch wire to hook to a temp sensor ect to kill it
As far as going back to generator mode it would seem if you applied power between the diode and moter it would generate as soon as your relay opened Or maybe use a double throw relay the normally closed contacts for batt charging
Motor to Generator operation Controller | 5 comments (5 topical, 0 editorial)
