Motor to Generator operation Controller | 5 comments (5 topical, editorial)
Re: Motor to Generator operation Controller (3.00 / 0) (#4)
by Ungrounded Lightning Rod on Sat May 17th, 2008 at 06:09:44 PM MST
Using a DC motor as a generator and an autostarter?
Just short the blocking diode to start.
Turn the short off after a timeout.  The engine is either running by then (and the motor running as a genny) or it's not (and requires manual intervention).
A high-current self-resetting circuit breaker protects from burnout if something is jammed and the motor doesn't spin up.
Motor to Generator operation Controller | 5 comments (5 topical, 0 editorial)
