When one part of the string starts to show lower sg you will need to divert more charging current to it by putting a shunt load across the over charged bit until the low bit equalises. Most likely the string of 7 will need equalising and a lamp across the odd pair will reduce its charging current in relation to the others. Do it when you have good charging conditions.
Flux[ Parent ]
