Low amperage output | 11 comments (11 topical, 0 editorial)
Re: Low amperage output (3.00 / 0) (#11)
by Flux on Mon May 19th, 2008 at 01:01:56 AM MST
A few things don't tie up. You should cut in at 24v with single phase when the peak ac equals the dc. Conduction will be small at the start and increase with speed. You should start to see output at 20v ac. If you get 60v ac at 370 rpm this implies a cut in of 370/3 which is nearer 123 than 190 rpm.
This is incredibly slow for a 5ft prop. I am not sure why you are getting best results with such a low cut in speed unless your prop is much lower tsr than you think. Certainly you are more in the speed range of the 8ft prop and whatever happens the large prop will have far more power. I am not sure that such a tiny alternator is going to hold down an 8ft prop so you will need to make every attempt to make it furl as early as possible. In low winds you will be way ahead but you will need to watch it in high winds.
