Heat from wind using inverter? | 6 comments (6 topical, editorial)
Re: Heat from wind using inverter? (3.00 / 0) (#5)
by commanda (alwynne at unwired dot com dot au) on Mon May 19th, 2008 at 03:24:07 PM MST
The turbine that I am buying has a built in charge controller.....
So what does the built in charge controller do once the batteries are full? It's not going to open circuit the mill, so it must dump the power somewhere.  You just need to reconfigure its dump load to heat water.
Re: Heat from wind using inverter? (3.00 / 0) (#6)
by samuk on Wed Jun 4th, 2008 at 02:25:15 AM MST
I belive it has a electromagnetic braking system.
Heat from wind using inverter? | 6 comments (6 topical, 0 editorial)
