Old forklift batteries | 13 comments (13 topical, 0 editorial)
Re: Old forklift batteries (3.00 / 0) (#7)
by Simen on Thu May 8th, 2008 at 04:35:33 PM MST
(User Info) http://www.mwlmf.net
A small update. :)
14.5hrs and the voltage has fallen from 12.35v to 12.27v with the 60W load. (plus 7.5W for the inverter itself.)
I think i'll keep this bank. ;) Even if it died now after drawing 80A total, it'll have its uses... ;)
Re: Old forklift batteries (3.00 / 0) (#8)
by dnix71 (yahoo.com 'dnix71') on Thu May 8th, 2008 at 05:09:52 PM MST
Equalizing is just overcharging a little so you cook off some of the water in the stronger cells. Once all of the cells are gassing, you have reached a full charge.
After equalizing, you add water to level all the cells off to the same height.
You always add water after charging and while it's still warm. If the cells have exposed plates, you can add just enough to cover the plates, then charge. If you add water before charging you risk an overflow since charging expands the electrolyte volume by heating it and introducing gas bubbles.
Re: Old forklift batteries (3.00 / 0) (#10)
by Simen on Fri May 9th, 2008 at 12:13:57 AM MST
Water filling is no problem on these cells. ;)
As mentioned before, these cells have Aquamatic plugs, similar to these:
http://www.hawkerpowersource.com/products/accessories.htm
Though, mine are the previous generation, without the hole for measuring the specific gravity; there is a small hole with a plug in the corner of each cell for that purpose. ;)
