I have the same problem: small chest freezer, <100W when running, won't start on an 800W generator. Kill-a-watt meter says it uses about 8 amps in the first second. It does start fine off my Prosine 2.0 inverter (rated >4000W surge, with 4/0 cables to the battery). I wonder if adding the capacitor etc would help the longevity of the inverter, by reducing the current surge through it on each startup of the motor?[ Parent ]
