Within reason you can put forward some case for several smaller ones compared with a big one, but that is questionable when you start mounting them on a common tower.
When you start crowding together large numbers of them then it becomes very doubtful. The efficiency will be low and the mounting will be a mess and you start to have to seriously think about how to control them in high wind.
There have been attempts to use the little Marlec machines mounted like a tree on a common tower with turbines on the branches, but they all steer and act individually. Doing as you suggest is not going to catch on soon.
Flux[ Parent ]
