Thinning Epoxy with lacquer thinner? | 18 comments (18 topical, editorial)
Re: Thinning Epoxy with lacquer thinner? (3.00 / 0) (#12)
by clflyguy (sidney.raiford@gmail.com) on Sat May 3rd, 2008 at 07:46:03 PM MST
Snowcrow,
 5 minute epoxy won't cure if thinned, period. Speaking from experience here. Like
Ron said and I agree, the 5 minute stuff barely qualifies as an epoxy. If acquiring
some decent epoxy to glaze your mold with is presenting a problem, then use
polyester. It will flow out nicely if worked quickly and LEFT ALONE. Don't be
tempted 4 1/2 minutes into the process to "touch up" that little place you just now
saw, let it cure. Sand and coat again. If the porosity has been filled then sand
out with some 400 grit and buff with a liquid buffing compound. If that is too
expensive for your tastes then use some baking soda mixed with regular crest
toothpaste thinned with a little water- no kidding (plus it makes your buffing pad
smell good). Rinse & wipe mold out well. Order some Meguires mold release wax. Wax
& polish with a soft cotton cloth after each of the 7 coats, put on at least an
hour apart. If you have designed your mold with a couple of degrees of draft angle
and if there is no porosity in the vertical surfaces then you can probably cast
your stator at this point without fear of sticking- it works for the pro's. If a
higher degree of certainty is required then mist on 2 light coats of PVA (poly-
vinyl alcohol, trade name Part-All) and your stator will virtually fall out of the
mold.
Re: Thinning Epoxy with lacquer thinner? (3.00 / 0) (#14)
by snowcrow on Sun May 4th, 2008 at 05:29:37 AM MST
  Thanks for chiming in clflyguy, I see you've done a fair amount of work with this kind of thing and will take your word on not thinning it.
  Unfortunately, I have already used the 5 minute epoxy, un-thinned, for my base coat. I didn't think using the stuff would turn out to be such an issue. Can I go over it with good stuff, (US Composites 635 thin epoxy) without any ill effects?
Blessings, Snow Crow
Re: Thinning Epoxy with lacquer thinner? (3.00 / 0) (#15)
by wdyasq on Sun May 4th, 2008 at 06:12:42 AM MST
Most epoxies bond to about everything. For molds, I don't think you will have a problem.
One thing that does work well is to warm/heat the part up before applying the resin. And yes, the epoxy can be warmed also. We are talking warming to 100F or so. This causes the epoxy to be a bit thinner and the air in the part will be expanded and as it contracts it will pull a bit of epoxy back in.
I am not familiar with the particular formulation of epoxy you are using but, pay attention to curing temperature and times. Epoxy curing times are cut in half with every 10C rise in temperature or so. Some epoxies will not cure properly below 60F/15C.
There are many 'tricks' to epoxy and most industrial processes. One must be careful which 'tricks' they use for which process. Some were invented by the worker/craftsman and are good 'tricks' and make good sense in saving time/money and building a better product. Other 'tricks' can compromise the integrity if a project but are still used because a craftsman is stupid/ignorant/lazy or a combination of the three. There is usually someone up the command/food chain that is a least as stupid/lazy/ignorant or has a 'don't give a damn' attitude allowing that practice to continue. Management can be as sorry as labor.
Regrets for the long-winded answer but, stupid shortcuts are one of my pet peeves. Although using resin in an improper way in a mold is unlikely to cause problems, I have seen some of these 'shortcuts' destroy very expensive equipment and had them come too close to being my final thoughts in this life a couple of times.
Re: Thinning Epoxy with lacquer thinner? (3.00 / 0) (#16)
by clflyguy (sidney.raiford@gmail.com) on Sun May 4th, 2008 at 08:07:04 PM MST
Yes, you can... just sand the 5 minute stuff with 220 before applying the good
stuff. It might gum up your paper, if so then go to a rougher grit. All you're
doing is making a more uniform surface for the next coat and providing micro-
scratches for better bonding of the good stuff. Win-win. Send pictures, I love
pictures... Gus
Re: Thinning Epoxy with lacquer thinner? (3.00 / 0) (#17)
by snowcrow on Mon May 5th, 2008 at 05:28:13 AM MST
  Thanks Gus, another question answered!!  I did sand the mold last night with 120 grit to smooth out the lumps and bumps.  I had let it cure for 24 hours, so it was nice and hard, not gummy at all.
 The 5 minute epoxy being as thick as it is, really worked good to seal the fiber board without causing it to swell.
 I'm doing the picture taking old school, seeing as I killed digital camera!!! I should have the roll finished up this week and have it post soon. Thanks again Gus!
Thinning Epoxy with lacquer thinner? | 18 comments (18 topical, 0 editorial)
