Linear Actuator with no limits | 13 comments (13 topical, editorial)
Re: Linear Actuator with no limits (3.00 / 0) (#5)
by DaveW on Sun May 4th, 2008 at 08:21:34 AM MST
Basil -
  I had much the same problem a while back.  I used an old timer from a non-working coffee maker and set the time to 9:00 PM.  The timer contacts are fed from the Dawn microswitch contacts so that if the tracker has not returned to the dawn position and the timer reaches 9:00 Pm then the tracker is forced to the start position.  Once the tracker faces East the dawn microswitch kills the power to the timer contacts and the system is ready for a new day.  This backup failsafe has worked for about 3 years now.
DaveW
Re: Linear Actuator with no limits (3.00 / 0) (#6)
by Basil (basil(spamblock)key@bellsouth.net) on Sun May 4th, 2008 at 08:31:56 AM MST
Thanks Thats what I needed to get the no sun problem out of the way. I will try it as soon as I finish the first part.
Bad luck or none at all.
Linear Actuator with no limits | 13 comments (13 topical, 0 editorial)
