Linear Actuator with no limits | 13 comments (13 topical, editorial)
Re: Linear Actuator with no limits (3.00 / 0) (#8)
by tecker on Sun May 4th, 2008 at 09:02:40 AM MST
 Printers have what you need . An optical gate you just need a tab on your mech to match up.
Re: Linear Actuator with no limits (3.00 / 0) (#9)
by JW on Sun May 4th, 2008 at 12:45:24 PM MST
   I would imagion that the higher the resolution at (floating)stoping points, could augment a more solid unit. Such as PWM would provide, like you can see on the futaba RC car servo's. 270* on a liner unit is quite versatile, but it would not be 2 axis, unless, it was tied to another (such as/same as)independant system. Its my understanding, this is not a servo control device.
JW
Linear Actuator with no limits | 13 comments (13 topical, 0 editorial)
