Air-X motor | 9 comments (9 topical, editorial)
Re: Air-X motor (3.00 / 0) (#1)
by ghurd on Tue May 6th, 2008 at 06:42:17 PM MST
My understanding of the Ametek 38 is they won't break 10A.
But in most places they will beat an Air-X for total power output.
Re: Air-X motor (3.00 / 0) (#2)
by Jerry on Tue May 6th, 2008 at 08:44:37 PM MST
Use a GE ECMM 1 HP. It will out preform the 403.
Airheads Page
Re: Air-X motor (3.00 / 0) (#3)
by Flux on Wed May 7th, 2008 at 02:56:18 AM MST
The Air X has a permanent magnet alternator. No major manufacturer would adapt motors. A few small manufacturers seem to sell things based on surplus Tape spool motors.
It is rated at 450W but it needs a good wind to do it. Ideal for marine applications or first class inland wind sites. It performs rather poorly in low wind areas as the compromises made to get the high top end performance ( sells better) make it virtually useless below 10 mph.
Energy capture is much more related to prop diameter than alternator maximum rating.
Most wind areas produce 90% of the energy in winds below 20 mph. A well designed 100W machine set up for low wind will capture more energy in most inland sites.
Air-X motor | 9 comments (9 topical, 0 editorial)
