Air-X motor | 9 comments (9 topical, editorial)
Re: Air-X motor (3.00 / 0) (#7)
by Flux on Wed May 7th, 2008 at 10:29:45 AM MST
The reason why it never comes close to 400W is because the dynamic braking will operate to hold speed. It should if set up correctly hit close on 400W instantaneous before braking. It is rated at 400W but as the duty cycle in high winds is low or very low the average power that you can measure into a load is way down and falls with increased wind speed.
In their data I think they claim peak so they are meeting the spec but realistically it is a poor 200W machine. The old 403 could just about do the 400W but the blade flapping speed regulating scheme produced noise that nobody could live with and they had to do something.
If you want to avoid furling or pitch control something has to give.
Probably the Amtecs can do as well in lower winds if correctly matched but a decent air gap alternator will out perform either.
Re: Air-X motor (3.00 / 0) (#8)
by JW1111 on Thu May 8th, 2008 at 05:16:47 AM MST
Thanks, the machine has served the purpose of getting me started.  But I think Southwest Windpower needs to take a course in business ethics with emphasis on the section related to false advertising.  I thought initially the Air-x was over-rated to bolster kilowatt-based wind energy tax subsidies. Now I think they are just a bunch of liars.  Thanks for your information.
Re: Air-X motor (3.00 / 0) (#9)
by Simen on Fri May 9th, 2008 at 12:51:29 AM MST
(User Info) http://www.mwlmf.net
Maybe that's why they've come up with the Air-Breeze? :D Very similar to Air-X, but with rated power at 200W, and a lower start-up speed.
Air-X motor | 9 comments (9 topical, 0 editorial)
