trojan t-105's | 7 comments (7 topical, editorial)
Re: trojan t-105's (3.00 / 0) (#1)
by DanG on Wed May 7th, 2008 at 09:16:48 AM MST
Sounds like you are are good to go as is...
 "a rough estimate of the actual SOC"
% of Charge - - - - - - Charging - - - - - - - At Rest - - - - Discharging
  1.  - - - - - - - - - - - - 14.75 - - - - - - - - 12.70 - - - - - - 12.50
  2. - - - - - - - - - - - - - 13.75 - - - - - - - - 12.58 - - - - - - 12.40
  3. - - - - - - - - - - - - - 13.45 - - - - - - - - 12.46 - - - - - - 12.30
  4. - - - - - - - - - - - - - 13.30 - - - - - - - - 12.36 - - - - - - 12.25
  5. - - - - - - - - - - - - - 13.20 - - - - - - - - 12.28 - - - - - - 12.15
  6. - - - - - - - - - - - - - 13.10 - - - - - - - - 12.20 - - - - - - 12.00
  7. - - - - - - - - - - - - - 12.95 - - - - - - - - 12.12 - - - - - - 11.90
  8. - - - - - - - - - - - - - 12.75 - - - - - - - - 12.02 - - - - - - 11.70
  9. - - - - - - - - - - - - - 12.55 - - - - - - - - 11.88 - - - - - - 11.50
  10. - - - - - - - - - - - - - 12.25 - - - - - - - - 11.72 - - - - - - 11.25
http://solarjohn.blogspot.com/2007/03/measuring-battery-state-of-charge.html
Re: trojan t-105's (3.00 / 0) (#2)
by Flux on Wed May 7th, 2008 at 10:44:01 AM MST
A desulphator will help if you believe that it works , otherwise save your money. If a good equalising charge doesn't fix it nothing is going to.
I would set the charge controller volts up higher than normal and gas them for a bit, then load test them and if they have responded set the controller settings back to normal.
Re: trojan t-105's (3.00 / 0) (#7)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Tue May 27th, 2008 at 08:55:34 AM MST
Thank You so much !!
W o o f -={(
trojan t-105's | 7 comments (7 topical, 0 editorial)
