Hughs 4 ft stator finished. | 10 comments (10 topical, editorial)
Re: Hughs 4 ft stator finished. (3.00 / 0) (#8)
by jmk on Wed May 7th, 2008 at 05:01:21 PM MST
 I did read the part where you used the shower. It's great way to conserve. I am surprised to see that the other resin is so clear. That's why I was wondering. My polyurethane resin hardens in a greenish - yellowish color. I use the Bondo brand. That's going to be a nice little geny. I am anxious to here its performance.
jmk
Re: Hughs 4 ft stator finished. (3.00 / 0) (#9)
by Jerry on Wed May 7th, 2008 at 06:52:30 PM MST
The clear part in the center of the coils is plexi. I cut 1"X2"X3X8" pice of plexi. I cut slots on the sides of the plexi. I use this as a bobin in the center of the coil winder. The plexi pice stays in the center of the coil and is cast into the mold along with the coil.
The slots on the sides alow me to used zip ties to hold coil shape. Latter I replace the zip ties with white cloth tape. During handleing the coils expand a littel but the precut cut out in the stator form squishes them back into shape.
Next step is bearing and shaft assembly. Then its about time to do some RPM, prime driver requierments, volts at rpm, amps at rpm, watts at rpm, temperature of coil at watts for time running.
Ofcourse all these test will be done in star and Jerry Rigged. I can tell you quite confidently That start will run quite hot.
Airheads Page
Re: Hughs 4 ft stator finished. (3.00 / 0) (#10)
by Jerry on Wed May 7th, 2008 at 10:41:12 PM MST
Whoops. I should have wrote "Star will run quite hot"
I was at the retail store and a big crowed of people came in. I tryed to finish up to fast.
Airheads Page
Hughs 4 ft stator finished. | 10 comments (10 topical, 0 editorial)
