Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor | 19 comments (19 topical, editorial)
Re: Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor (3.00 / 0) (#16)
by Flux on Sun May 11th, 2008 at 12:28:27 AM MST
I have no idea of your wind conditions, but if you are getting 1.5A from that with pvc blades then that is not too bad.
If the problem is just lack of prop speed then gearing it will help. If you are in a low wind area then the additional gearing loss may even make it worse.
If by any chance you can find a 6v battery and try charging that you will have a better idea. If it works far better into 6v with more power ( not just amps, i.e. more than twice the amps) then you will gain with gearing or a boost converter.
"What about building a VAWT type design and put the treadmill motor under it, would that work? like many people have made VAWT's with PVC and other materials, you may have seen those."
Talk to them about it, just my personal opinion, just don't waste your time.
Re: Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor (3.00 / 0) (#17)
by farhan on Sun May 11th, 2008 at 12:19:21 PM MST
Ok, i won't waste time with VAWT's for this motor and setup.
Yes many times i have seen close to 1.5A, normally its between 0.7 to 0.8A. I like very close to sea in Karchi, just 5 minute drive sea shore. Thats why the swirling winds, i checked the data from the websites, they say it was 18MPH today. We do get good wind here and my home has no big buildings near it except 1 3 stories building just across the street.
Another friend of mine suggested the same thing that try and charge a 6V battery with it first, i'll try that. Yes with 4 PVC blades 2ft long i'm getting this result, i wanted 3 blades but the person i got the hub drilled from made a mistake and its not 120 degree. when i put three blades it doesn't look evenly balanced.
How much difference can i get from wooden blades? like have told you what readings i get now, max i got 1.5A and about 18V.
How to gear is what i want to know, timing belt type on pulleys or chain on sprockets. What gear ratio's, maybe that i'll have to keep trying and find out, you can't help me with this i know because till you see it you can't tell.
Re: Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor (3.00 / 0) (#18)
by farhan on Thu May 15th, 2008 at 03:31:21 PM MST
Hello,
As told by you all to make wooden blades, i can't seem to get that much time from work to do it for now.
I have put the gen up and put a 15amp blocking diode and just for checking a 12V 7Ah lead acid battery which i had new from a ups, as my mill hardly makes more than 1.5amp, is it the diode enough? how long should it take to charge this battery to be of any use?
Kindly please help with the gearing issue too, i'm stuck with 7-9volts, it reaches 12-14v but not for long and 2-3 times an hour hardly.
What should i do now?
Re: Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor (3.00 / 0) (#19)
by Flux on Fri May 16th, 2008 at 01:30:43 AM MST
Try gearing 2:1 with a bike chain and a pair of sprockets.
Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor | 19 comments (19 topical, 0 editorial)
