Ok, i won't waste time with VAWT's for this motor and setup.
Yes many times i have seen close to 1.5A, normally its between 0.7 to 0.8A. I like very close to sea in Karchi, just 5 minute drive sea shore. Thats why the swirling winds, i checked the data from the websites, they say it was 18MPH today. We do get good wind here and my home has no big buildings near it except 1 3 stories building just across the street.
Another friend of mine suggested the same thing that try and charge a 6V battery with it first, i'll try that. Yes with 4 PVC blades 2ft long i'm getting this result, i wanted 3 blades but the person i got the hub drilled from made a mistake and its not 120 degree. when i put three blades it doesn't look evenly balanced.
How much difference can i get from wooden blades? like have told you what readings i get now, max i got 1.5A and about 18V.
How to gear is what i want to know, timing belt type on pulleys or chain on sprockets. What gear ratio's, maybe that i'll have to keep trying and find out, you can't help me with this i know because till you see it you can't tell.
