Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor | 19 comments (19 topical, editorial)
Re: Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor (3.00 / 0) (#9)
by farhan on Fri May 9th, 2008 at 12:58:05 AM MST
Got your point thank you, please tell me why can't we use normal ceiling fan blades for this purpose, they are cheap and made of metal so long lasting and must have been checked in wind tunnels and all for best angle and performance by the companies.
For wooden blades whats the best angle at which i should carve it to better work in low winds?
Re: Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor (3.00 / 0) (#10)
by Flux on Fri May 9th, 2008 at 03:58:54 AM MST
Fans are designed to make wind not convert it to work. The aerofoil surfaces are back to front for use as a prop. Yes they work up to a point but the angles and profiles are wrong for good results.
There are various blade calculators that will give you the angles and widths such as Alton's. I am sure Hugh Piggott has a spreadsheet that does the same thing on his site.
At http://www.scoraigwind.com/
Re: Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor (3.00 / 0) (#11)
by farhan on Fri May 9th, 2008 at 04:12:05 AM MST
thank you for your help, really appreciate it.
I'll check and read out that website for making wooden blades which i need as you suggested, the PVC one's i made will have to be kept aside then because not good as you said.
Yes fan blades are manufactured to make wind that is right, but i was just thinking its metal and its angel can be changes, i mean it can be reshaped easily, just a thought i know silly question : )
Turdan DCPM 180V 4000RPM 1.5HP Treadmill Motor | 19 comments (19 topical, 0 editorial)
